I am using TDMS Reserve File Size function in niScope EX Stream to Disk.vi sample program to perform continuous acquisition to disk but when I executed the program, I get below error. How to solve this issue?
If the error persists, check the Maximum Points per Fetch function and make sure the value used at this function is multiple of disk sector size, which is typically number like 512, 1024, 2048 and etc.
