Reference to DLL Could Not Be Added When Calling LabVIEW-Built DLL From C# Code
Updated Aug 21, 2024
Programming Language
  • C# .NET
  • Visual Basic .NET
Other
  • Visual Studio
I created a program in LabVIEW that is using USB-8452 to communicate with an I2C device. Then, I generated a shared library (.dll) using LabVIEW Application Builder. However, I am encountering an error when trying to call this DLL in the C#.NET environment.
The error message is:
"A reference to '~.dll' could not be added. Please make sure that the file is accessible, and that it is a valid assembly or COM component."
I want to call the DLL created on PC B (LabVIEW development PC) in PC A (C# development PC). The environment is as follows.
PC A: Microsoft Visual Studio Express 2017
PC B: LabVIEW 2021 SP1 32bit
LabVIEW Runtime and USB-845x driver are already installed on PC A.
If you are using .NET programming language to integrate LabVIEW-built shared library, it is highly recommended to build a .NET Interop Assembly DLL instead of Shared Library DLL.
.NET Interop Assembly is using .NET framework which is compatible with .NET programming language such as C# or Visual Basic.
If you need to call Shared Library (DLL) from .NET programming language, refer to How Do I Use a LabVIEW-Built Shared Library in a .NET Project? article.
