Simulink HDL Workflow Advisor中“Set Target Reference Design”失败
更新 Aug 29, 2024
  • MATLAB
  • Simulink
  • LabVIEW FPGA Module
我想从Simulink HDL模型生成FPGA bitfile。在HDL Workflow Advisor的1.2 Set Target Reference Design中,单击Run This Task后,HDL Workflow Advisor返回错误:
Failed Object reference not set to an instance of an object.
Error using PostCallbacks.CustomReferenceDesignCallback
Error in hdlturnkey.plugin.runCallbackCustomizeReferenceDesign
Error in hdlturnkey.plugin.ReferenceDesign/customizeReferenceDesign
Error in hdlturnkey.plugin.ReferenceDesignList/reloadRDPlugin
Error in hdlturnkey.ip.HDLTargetDriver/reloadReferenceDesignPlugin
Error in hdlturnkey.ip.HDLTargetDriver/validateTargetReferenceDesign
Error in setTargetReferenceDesign
Error in Simulink.ModelAdvisor/executeCheckCallbackFct
Error in Simulink.ModelAdvisor/run
Error in Simulink.ModelAdvisor/runCheck
Error in ModelAdvisor.Node/runTaskAdvisor
为什么我会收到上述错误呢?
多个步骤可以解决此问题:
  • 如果MATLAB不是以管理员身份运行的,请确保在LabVIEW.exe Properties的Compatibility中未选中Run this program as an administrator。
  • 如果MATLAB是以管理员身份运行的,请确保在LabVIEW.exe Properties的Compatibility中选中了Run this program as an administrator。
