I want to generate FPGA bitfile from Simulink HDL model. In the
1.2 Set Target Reference Design of
HDL Workflow Advisor, after clicking
Run This Task, HDL Workflow Advisor return an error:
Failed Object reference not set to an instance of an object.
Error using PostCallbacks.CustomReferenceDesignCallback
Error in hdlturnkey.plugin.runCallbackCustomizeReferenceDesign
Error in hdlturnkey.plugin.ReferenceDesign/customizeReferenceDesign
Error in hdlturnkey.plugin.ReferenceDesignList/reloadRDPlugin
Error in hdlturnkey.ip.HDLTargetDriver/reloadReferenceDesignPlugin
Error in hdlturnkey.ip.HDLTargetDriver/validateTargetReferenceDesign
Error in setTargetReferenceDesign
Error in Simulink.ModelAdvisor/executeCheckCallbackFct
Error in Simulink.ModelAdvisor/run
Error in Simulink.ModelAdvisor/runCheck
Error in ModelAdvisor.Node/runTaskAdvisor
Why do I get the above error?
