These steps require Administrator permissions and remote access to the system.
1. Open the Windows Services Manager (type “Services” into the Start Menu) and disable "NI SystemLink Forwarding Service". This will prevent it from running automatically in the background while manually running it. Be sure to turn this back on when you are done (restarting the system also turns it back on).
2. Ensure that there is data in the store directory “C:\ProgramData\National Instruments\Skyline\Data\Store” (see Manually Inspecting SystemLink Store and Forward Stored Transactions). If not, run some tests in TestStand to generate data.
3. Open a command prompt and run the following:
"C:\Program Files\National Instruments\Shared\Skyline\Forwarding\nisystemlinkforwarding.exe" -v
4. A new command prompt will appear that will include detailed logging. Unfortunately, you cannot specify a file to log to or redirect the output to a file, so you will have to copy/paste from the console window to a file. If there are lot of files in the store directory, the command prompt will run out of space before it reaches the end. You may need to monitor it and capture parts of the log early in the process, errors will likely occur early. If there is a lot of data, the forwarding process can take hours.
5. Re-enable "NI SystemLink Forwarding Service" in Windows Service Manager or restart the client system.
