Status Code -50152 in NI MAX When Using PXIe-1090 Chassis
Updated Aug 15, 2024
  • PXIe-1090
I have a PXIe-4468 installed in a PXI express slot and PXI-6221 installed in a hybrid slot of the PXIe-1090 chassis. If there is only one module installed to the PXIe-1090, no error occurred but when both modules installed to the chassis, I am getting an error as shown below in NI MAX.
Status code: -50152
A hardware failure has occurred. The operation could not be completed as specified
How can I solve this error?
The firmware, which should deploy automatically when the driver loads, is failing to do so, resulting in error -50152, indicating a hardware failure.
To solve this issue, you can set up scheduled task to automatically restart the driver by following the steps below:
  1. Open Device Manager and look for the module driver.
  2. Right click the module driver and select Properties.
  3. In the Details tab, select Device instance path from the drop-down menu and copy the value.
  1. Open Task Scheduler and click Create Task....
  1. Enter a name for the task and tick Run with highest privileges.
  1. In the trigger tab, create a new trigger and set the Begin the task to At log on.
  1. In the Actions tab, click New.
  2. Select Start a program for Action, enter pnputil for Program/script, and for Add arguments (optional), enter /restart-device "Paste_the_Device_instance_path_here" and click OK. You should see something like figure below.
  1. Click OK to create the scheduled task.
  2. Restart your PC and check if the script run automatically to resolve Error -50152 in NI MAX.
Alternatively, you can manually restart the driver by disabling and re-enabling the module in Device Manager to clear the error.
