Integrating R Code with LabVIEW
Updated Aug 14, 2024
Other
  • R (programming language)
I need to use certain function in R (programming language) with LabVIEW. Does LabVIEW support of calling R code? If possible, how can I call R code from LabVIEW?
LabVIEW is not officially supporting R programming language. Below is suggested workaround to integrate R with LabVIEW.
  1. You can create a wrapper on the R code with LabVIEW supported programming language.
  2. Use TCP (or any other communication protocol supported by R and LabVIEW) to exchange data between LabVIEW and R.
LabVIEW officially supports Python, MathWorks® MATLAB® Software, and C/C++. You can use those languages as a wrapper to R code.
