Unable to Install LabVIEW 2022 Q3 on Ubuntu 22.04
Updated Aug 16, 2024
  • Linux
I was installing LabVIEW 2022 Q3 on Ubuntu 22.04 but suddenly got below error and the installation was unsuccessful
The following packages have unmet dependencies:`
 ni-syscfg-runtime : Depends: zip but it is not installable
 ni-wine : Depends: libncurses5 but it is not installable
           Depends: libldap-2.4-2 but it is not installable
           Depends: libopenal1 but it is not installable
E: Unable to correct problems, you have held broken packages.
Un-registering ubuntu Feed
This is a Known issue in installing LabVIEW 2022 Q3 on Ubuntu 22.04 where the dependencies for the installation went missing.
Beginning with version 22.04, Ubuntu distribution does not shipped with libncurses5, libldap-2.4-2, and libopenal1.
However, these libraries are necessary to install LabVIEW in Ubuntu because they are among the dependencies required.
As a workaround, it is recommended to install NI Hardware Configuration Utility from NI Linux Device Driver 2024 Q4 or later before installing LabVIEW 2022 Q3 in Ubuntu 22.04. This will help to provide LabVIEW with updated version of components that do not rely on the missing legacy components.
