The reason for this error to happen is that the NI Route Coordinator service did not work as expected, which is caused by Kernel DMA Protection, thus causing the error to reoccur whenever the PC is being restarted even after the error had been fixed.
You will be able to solve the error by
disabling the Kernel DMA Protection , but if you are unable to disable it, another workaround is to delay the start of the NI Route Coordinator service. Delaying the service will cause the delay of new hardware connected to be detected by the PC but they will still be able to be detected in NI MAX. This can prevent the error to reoccur immediately after restarting the PC.
To delay the start of NI Route Coordinator in your PC, please follow the steps listed below.
1. Go to Window Search bar and search for
Services.
2. Right click the
NI Route Coordinator and select
Properties.
3. Once the properties window appears, change the Startup type to
Automatic (Delayed Start).
4.
Reset NI MAX configuration and reboot the system.
