Matplotlib Compatibility Issue with TestStand 2022 64-bit
Updated Jul 26, 2024
  • TestStand
Programming Language
  • Python
I would like to confirm if the Python Matplotlib library can be used with the TestStand Python Adapter.
I'm using a Python Action step to call a function using the Matplotlib library for Python, the step shows the following error message: "Unable to load the the Python module.".
Please refer to the screenshot for error detail:
The system has TestStand 2022 64-bit and Python 3.8.8 64-bit with Matplotlib 3.8.
Yes, Teststand 2022 64-bit does support the Python Matplotlib library.
TestStand supports virtual environments created using the virtualenv tool.
The issue can be fixed by aligning the Matplotlib library version in global environment with the virtual environment.
