I am measuring resistance from an AI channel to the ground on an NI-9208, and I am receiving values as low as 73.9, and some as high as 77.3, and I am concerned because of the difference I get.
Using Ohm's law, I can provide a constant 4mA input to every channel and get different V results. Using a DMM, here are the R values I got on a few channels:
AI0 = 73.9
AI1 = 76
AI2 = 74.2
AI3 = 74
AI4 = 77.1
AI5 = 74.7
AI6 = 77.3
What should the R-value be for these channels? And should there be a 3.5 Ohm difference between low and high in the above values?
