When self calibrate PXIe-5114 in MAX I got the following error:
错误代码: 8000FFFF 无法校准设备 Error code -8000FFFF Unable calibrate device.
Here is the screenshot:
The code which calls self-calibrate to the scope will hang then crash as well.
OS is Windows10 and it's found the issue can happen on NI Scope driver version 19.0, 20.0. Under same software environment this issue does not happen on NI Scope driver version 21.0, 22.5, 23.5.
