How Do I Find the Origin of the Front Panel?
Updated Dec 6, 2024
My front panel is quite large. While editing my VI, I couldn't find its origin. How can I return to the front panel's origin?
  1. Open the Quick Drop Window.
  2. Then, press <Ctrl-O>. This shortcut key resets the scroll position of the front panel or block diagram to place the origin (0,0) in the upper left corner. If the front panel has multiple panes, then each pane is scrolled in this manner.
