When you generated one 802.11be 40MHz signal by RFmx Waveform Creator for WLAN with all original default parameters, you would find below warning message:
You can try to change the power level , but could not fix the warning message. How to fix it in SFP? Why does the warning message only show on 802.11be 40MHz , not showing for 20M/80M/160M/320M ?
