This is because the “Performance Optimized” option is enabled in the BIOS (version 2.1.10f0) under Advanced > System Profile Configuration > System Profile for your PXIe-8840QC, which enables Hyper-Threading and C-STATE. This can potentially trigger errors in the i7-5700EQ CPU controller.
You can resolve this issue by changing the setting to “OS Defined” in the BIOS.
