In your daily work , you should generate and analyze continuous CA signal sometimes; How could you generate one continuous CA signal by RFmx Waveform Creator ? And how could you set the RFmx Software Front Panel to demodulate the continuous CA signal ?
Here is NR continuous CA as an example to show you how to setup it ; 1.Open RFmx Waveform Creator to create NR continuous CA signal (5CC*20MHz) Select the Carrier Allocation and Channel Bandwidth:
Set the Modulation Type and other parameters:
Set Multi-Carrier parameters:
Check the waveform before generate it , Click Graphics --> Regenerate Plot button
Set the Center Frequency , Power Level , Trigger and Reference Source:
2.Setting RFmx NR to demodulate the signal Setting the basic key parameters:
Check the NR Setting panel , there is only one carrier:
Add carriers by Duplicate button matching RFmx WFC setting:
Check the parameters (Frequency , Bandwidth , Cell ID) of each carrier matching RFmx WFC setting:
Completed above actions , you can see below correct measurement result for multi-carrier;
