Change Scale of ColorRamp from Vertical to Horizontal
Updated Jul 3, 2024
Is it possible to change the scale of the color ramp from vertical to horizontal?
It is impossible to change the scale of ColorRamp from horizontal to vertical with property node. Similar like slider, you cannot change a slider between horizontal and vertical. You have to replace one with the other. But unfortunately, NI only provided ColorRamp with vertical scale in the Controls Palette for this time being.
