Review and Update from Type Def. Dialog Box is Not Showing in LabVIEW
Updated Jul 2, 2024
When trying to resolve the type definition instance on the front panel or the block diagram and select Review and Update from Type Def the dialog box is not showing.
There is a display issue when using Multiple monitors causing the dialog box not to appear when selecting Review and Update from Type Def. To solve it disconnect the other monitors and select Review and Update from Type Def again, or make sure that the dialog box is not appearing on one of the different screens.
