The Size of the Title Bar is Longer Than the Rest of the VI
Updated Aug 8, 2024
I am using LabVIEW on Windows 11 22H2. I unchecked Allow user to resize window in the Customize Window Appearance settings under VI Properties and set Window Runtime Position settings to Maximized. However, when I run the VI, the title bar is longer than the rest of the VI.
This issue occurs when using LabVIEW on Windows 11 22H2 and above. As a temporary solution, use Windows 11 21H2 or earlier. This issue is expected to be fixed in LabVIEW 2024 Q3 release.
