Reading Properties at File Level in DIAdem
Updated Jul 31, 2024
  • DIAdem
Can I access the base properties at the file level in the Data Portal if I want to upload further data files there?
The desired functionality can be achieved by using the following script:
ip.PropertyHandling.InheritanceMode = ePropInheritanceCopyToChannelLevel
This means that properties assigned to the file are transferred to the new channels and are therefore available for further use.
