Custom devices for VeriStand can be developed in LabVIEW and are needed to implement complex or specialized processing that cannot be achieved using VeriStand's built-in capabilities.
In this article we will see how to define properties for the sections and channels available on your custom device and then use these property values to set parameters for processing on the target.
If you don’t have a project template to create a custom device, please follow
this article to complete the preparations to be able to use a project template.
