In this tutorial, you'll learn how to read the status of your peripheral devices, such as your keyboard or mouse, while interacting with another application on your computer (i.e., when the LabVIEW application window is inactive).
In LabVIEW, events (those defined in an Event Structure) are designed to respond to user interactions with the LabVIEW Front Panel. When you switch to another application or window, LabVIEW stops receiving these events because it is no longer the active application. For example, if you define an event in an Event Structure to detect when the mouse is clicked, LabVIEW will stop receiving this event when you interact with another application because it is no longer the current active window.
This is standard behavior for most windowed applications on operating systems like Windows. Simultaneously receiving low-level input events can cause conflicts and resource contention, so it is generally not recommended. However, it is possible to achieve this through DLLs.
Check the following example to learn how to implement this in LabVIEW.
