For the chassis slot that is connected to a PCIe switch on the backplane, you may refer to the user manual of the chassis to understand which slot is connected to the PCIe switch instead of connected to the controller slot directly.
For example, referring to the PXIe-1088 chassis, you may notice that slots 2, 3, 5, 7, and 9 are connected to the PCIe switch. Meanwhile, slots 4, 6, and 8 are connected directly to the controller. This means that impacted modules in slot 4, 6, and/or 8 may experience the link-up issue.
