LabVIEW Remote Panel Request For Control Denied
Updated Dec 15, 2025
  • LabVIEW Remote Panel Server
I'm using LabVIEW Remote Panel Methods .lvproj and able to connect remote panel on host machine. However, when I tried request control on remote panel, it shown Request for control denied.
How should I solve this permission issue?
This issue happen when Browser Access in Web Server only granted viewing.
To allow client have controlling privilege, you may go to Tools >> Options >> Web Server >> Browser Access, configure browser address as Allow viewing and controlling.
If you are using a LabVIEW Remote Front Panel connection through an executable (EXE) as a server, make sure the EXE’s INI file (e.g., MyApp.ini) includes the following configuration:
WebServer.TcpAccess="c+<your_client_ip>"
For multiple client IP addresses, use:
WebServer.TcpAccess="c+10.155.6.27;c+10.155.14.53"
To allow access from all IP addresses (not recommended for security reasons), use:
WebServer.TcpAccess="c+*"
You can configure the asterisk (*) as shown in browser access list to grants control access to any IP address.
