Can NI PXIe-1088 Operate With a Timing and Synchronization Module?
Updated Jun 4, 2024
  • PXIe-1088
  • PXI-6683
  • PXIe-6674T
I have a NI PXIe-1088 and looking at the front panel in theĀ specification sheet, I don't see a Timing and Sync slot. Are timing and sync cards like the NI PXI-6674T not usable with the NI PXIe-1088?
Low cost chassis (like the mentioned PXIe-1088) do not have a system timing slot. However user could still use a compatible T&S module (e.g. PXIe-6683H) to route trigger signals to/from the backplane, but user won't be able to overwrite or import/export clock signals
