Archived:Error 32812 Occurs at FP Read vi When Using NI cFP-22xx
Updated Aug 18, 2025
  • cFP-2200
  • cFP-2210
  • cFP-2220
  • NI-FieldPoint
  • When I run my VI, undefined error 32812 occurs in FP read VI.
  • Occasionally, undefined error 33162 occurs.
This issue occurs because NI cFP hardware is not properly detected in NI MAX. Make sure NI cFP hardware is properly recognized in NI MAX before running any related VIs. If NI cFP hardware cannot be detected when using static IP, please reset NI cFP network configuration and reconfigure the network configuration. Please refer to your hardware's manual for instructions.
