Ensure that the input parameter for the
Mean(DBL).gvi function is greater than 0. If the input parameter is equal to 0, it means the input parameter for the AC/DC RMS function is empty. It's crucial to use debugging tools to examine each function and identify the point at which the data becomes 0.
Mean(DBL).gvi is located in
AC/DC RMS.gvi's diagram. Follow these steps to find the .
gvi.
- Right-click on the AC/DC RMS.gvi and choose Open >> Diagram.
- After opening the diagram double-click on the gvi to open the main code inside it.
Double-check that the input data matches the required data for
AC/DC RMS.gvi.
