Time Gap between the Index in TestStand Execution Profiler
Updated May 21, 2024
  • TestStand
I notice that there is a time gap difference between the execution in TestStand Execution Profiler as shown in below.
What is causing this time gap difference?
The reason the user is seeing gaps in the execution profile is due to how the data collection is set up in the tool. By default, Process Model execution threads are not included in the captured or displayed data.
You can enable the Process Model execution threads logging by navigating to File >> Configure Data Collection to launch the Configure Data Collection window.
Make sure that the checkbox for Process Model is ticked.
After that, you need to navigate to View and make sure Show Process Model is checked so that the Process Model execution threads will be shown.
After changing the settings as above, you will see more details on the TestStand Execution Profiler.
