How To Create One LTE Multiple Cluster Waveform
Updated May 20, 2024
  • RFmx LTE/LTE-Advanced
  • RFmx Waveform Creator
When you want to measure MPR cases , you will create the multiple-cluster waveform, like below configuration list :
There is no example waveform file or help information about how to create it . How could you use RFmx Waveform Creator to create the multi-cluster waveform ?
Here is one example how to create above item10 waveform for your reference;
1. Create one LTE FDD waveform
2.Change the Channel Bandwidth as 20MHz , Change the Resource Allocation Type as 1; Then you can see the RBG parameters setting selection items showing in panel;
3.Setting RBG1 and RBG2 parameters matching the cluster1 and cluster2 ;
Measured the multiple-cluster waveform by RFmx LTE/LTE-Advanced , you can see below expected result:
