Before LabVIEW 2024 Q1 (after 2020), if there are any Interface classes in the LabVIEW project, the Unit Test functionality will have problems. There are two solutions to this issue:
- (Recommended) Upgrade LabVIEW and the UTF tool to the latest version.
- If you need to ignore this error in an older version of LabVIEW, you can replace the attachment from this article to the specified location:
- LabVIEW 2024:
C:\Program Files\NI\LVAddons\utf32\1\vi.lib\utf\common\file\ - LabVIEW 2020–2023 32-bit:
C:\Program Files (x86)\National Instruments\LabVIEW xxxx\vi.lib\utf\common\file - LabVIEW 2020–2023 64-bit:
C:\Program Files\National Instruments\LabVIEW xxxx\vi.lib\utf\common\file
Notes:
- Remove the version name from the replacement file before replacing it.
- You may need administrator privileges to replace this file.
- The LabVIEW 2024 UTF does not distinguish between 32-bit and 64-bit versions.
- The replacement attachment for each corresponding version does not distinguish by bit version.
