In order for you to configure the access control using the Domain Account Manager you need to have the LabVIEW Datalogging and Supervisory Control Module and use a 32-bits version of LabVIEW. The access control is used to control the way a user or group interacts with the front panel once the VI is running, however, every user can edit the block diagram.
Once you have created the Local Domain you can open the VI you want to configure the access control to.
- Select Tools»Security»Front Panel Security.
2.Select the control or indicator you want to change the access.
3. Click on
Add.
4. Select the Domain created and then select the user or group you want to grant or deny access.
5. In the Security Tab click on
Access to display the different options of access you can grant to the user/group selected prior.
6. Click
Ok to save the changes. After that configuration is done run the VI to confirm if the access granted before are working correctly.
