Which Version LabVIEW Support Ultra-Wideband Test Toolkit 23.0
Updated May 13, 2024
  • Ultra-Wideband Test Toolkit 23.0
There is no information about which version LabVIEW supporting Ultra-Wideband Test Toolkit 23.0 .  Customer will install the Ultra-Wideband Test Toolkit 23.0 , they want to know what software drivers needed before they install the Ultra-Wideband Test Toolkit 23.0.
Check the release note , there is no related information.
Ultra-Wideband Test Toolkit Release Notes - NI
LabVIEW 2020(64bit) is the only one driver supporting Ultra-Wideband Test Toolkit 23.0 .
Customer can find the related information in the user manual document, you can check the local path C:\Users\Public\Documents\National Instruments\NI-UWB\Documents\NI-UWB User Manual.pdf  after you installed the Ultra-Wideband Test Toolkit 23.0.
