NHR System Service Status
Updated Jul 10, 2025
System
  • NHR-9300
  • NHR-9200
  • NHR-4300
Other
  • The services location for Depot Repairs and Depot Calibrations has moved from the NHR facility located in Irvine, CA, to NI’s Austin Service Center located in Austin, TX as well as our Debrecen Service Center located in Debrecen, Hungary.  The new addresses for RMA and Depot Calibrations will be 11500 N. Mopac Expwy., Austin, TX 78759-3504, or Debrecen, Határ út 1/A, 4031 Hungary.
  • Due to supply chain challenges and component obsolescence and material shortages, starting October 09, 2023, we are no longer able to provide all services and production capabilities offered for some products. These products are indicated with a *
Which services are available for NHR systems?
ModelRepair/RMAOn-site Support CalibrationRemote Technical Support
9200 (NI built 4912 mod)YesNoField[1]Yes
9300YesYesField[1]Yes
9400 System CabinetsNoNoNoNo
94xx (4kW and 8kW versions only) No No No No
9430YesNoFactory[2]Yes
9420YesNoFactory[2]Yes
9410YesNoFactory[2]Yes
S430 Test System*NoNoField[1]Yes
S440 Test System*NoNoField[1]Yes
S450 Test System*NoNoField[1]Yes
S600 Series Systems*NoNoField[1]Yes
41xx DC Loads* NoNoField[1](In Situ)Yes
4212 DC Loads* NoNoField[1](In Situ)Yes
43xx Systems*LimitedNoFactory[2]Yes
46xx Systems*NoNoFactory[2]No
47xx Systems*NoNoFactory[2]No
4960 System*LimitedNoField[1]Yes
5500 Test System*NoNoField[1]Yes
5600 Test System*NoNoField[1]Yes
5710 Test System*NoNoField[1]Yes
61xx DC Sources*NoNoField[3](in Situ)Yes
UC3100 Calibrator*NoNoNoNo
1Field – the service is performed in the field by a trained technician following repair guidance from manuals.
Factory – these services are only available at the NI Service Center.  No field services are offered.
3 In Situ – Calibration is performed with components left in place.  Some disassembly may be required, but not full removal.
