Error: 0x00001F9 When Using LabVIEW Database Connectivity Toolkit
Updated Jun 28, 2024
I have a LabVIEW application that uses the LabVIEW Database Connectivity Toolkit to access a database. When I tried to close the connection to the database, I get the following error:
  • DB Tools Close Connection.vi->insertIntoDatabaseTables.vi->main.vi<ERR>ADO Error: 0x000001F9
    Open command object. Rollback database transaction.
The error message happens because when you close that connection another VI, a sub VI or possibly another program wants to use the connection. You have to make sure there is no other part in the code that still calls the database.
