The truth table output of this model is inverted which causes the issue above. Follow the below steps to modify the truth table:
- Double-click the IC in Multisim.
- Select the Value tab and choose Edit model.
- Replace the model truth table with the below truth table and select the Change component.
+; LT' RBI' D C B A BI/RBO' A B C D E F G
+ H H L L L L H L L L L L L H
+ H H L L L H H H L L H H H H
+ H H L L H L H L L H L L H L
+ H H L L H H H L L L L H H L
+ H H L H L L H H L L H H L L
+ H H L H L H H L H L L H L L
+ H H L H H L H H H L L L L L
+ H H L H H H H L L L H H H H
+ H H H L L L H L L L L L L L
+ H H H L L H H L L L H H L L
+ H H H L H L H H H H L L H L
+ H H H L H H H H H L L H H L
+ H H H H L L H H L H H H L L
+ H H H H L H H L H H L H L L
+ H H H H H L H H H H L L L L
+ H H H H H H H H H H H H H H
+ X X X X X X L H H H H H H H
+ H L L L L L L H H H H H H H
+ L X X X X X H L L L L L L L
+ H X X X X X H L L L L L L L
