PXIe-8301 not Detected on NI MAX after BIOS Upgrade
Updated Apr 18, 2024
  • PXIe-8301
  • PXI Platform Services
I just updated the BIOS on my Windows 10 computer and suddenly my PXIe-8301 and other PXI(e) cards do not detected on NI MAX and Windows Device Manager.
Check if the Thunderbolt™ 3 Security Level in BIOS Setup is set as Security Level: User Authorization. If you did not see this setting on your BIOS setting, there is possibility this setting has been locked out after BIOS upgrade. Please consult with your PC manufacturer to enable the Thunderbolt™ 3 Security Level setting again.
