SystemLink™ Grafana Dashboard Not Applying Colour Value Mapping
Updated Oct 23, 2026
  • SystemLink
  • SystemLink Jupyter Notebook Add-On
  • SystemLink Server
  • SystemLink Base
  • SystemLink Full
  • SystemLink Professional
  • SystemLink Enterprise
  • I have created a visualization panel in SystemLink™ Grafana, but when I apply a Value Mapping, nothing happens. How can I fix this?
  • In a SystemLink™ Grafana dashboard, I want to change the color of cells in a table. I have tried adding Value Mappings and Overrides, but nothing works.
  • I have applied a Value Mapping to my Grafana dashboard (similar to the below image) but my table never updates. What am I doing wrong?
A Value Mapping or Color Scheme Override will not appear on a Grafana panel (such as a table) unless the panel's Cell Type has been configured properly.
To configure the Cell Type to allow for background or text color changes, follow the steps below:
  1. Select the All tab from the panel options.
  1. Scroll through the list of options to find Cell Options >> Cell Type.
  2. Set Cell Type to Colored Text or Colored Background, depending on your preference.
  1. The Value Mapping or Override should now apply. If not, click Apply to save your changes.
  2. [OPTIONAL] If your panel applies other colors that you did not define in a Value Mapping or Override, it is also necessary to change the Color Scheme option:
    1. Continue scrolling through the list of options until you find Standard Options >> Color Scheme.
    2. Change the value to Single Color.
    3. To the right of the drop-down menu, select the circle icon to select a color. Select the Transparent option.
    4. Click Apply to save changes.
