Input Name Constant Incorrect For Array Split / Replace Subarrays In Place Element Structure
Updated Apr 5, 2024
Why is the input name constant is showing up as diagonal instead of split length in LabVIEW 2023 Q1 (32-Bit). Even though the documentation would sujest that it is split length
In LabVIEW 2024 Q1, LabVIEW 2022 Q3 and LabVIEW 2017 this is showing up correctly as split length.
LV 2023 Q1 (32-Bit):
LV 2017/ 2024:
