Error -380551 When Trying RFmx NR Noise Calibration
Updated Sep 10, 2024
  • PXIe-5842
  • RFmx
  • InstrumentStudio
I am using a PXIe-5842 with RFmxNR API for LabVIEW and Instrument Studio to measure EVM, when I use the "calibrate" function, I receive the error -380551:
The error happens because the MM1 (VST3 54 GHz Frequency Extension) doesn't support RFmx NR Noise Calibration.
If you want to calibrate the device a regular self-calibration can be done, just not the EVM noise calibration/compensation
