RMX programmable power supplies cannot sink reverse current from the load. Therefore, if a regenerative load (such as an inverter, converter, or transformer) is connected and tries to sink power into the power supply terminals, the output voltage will increase and become unstable. This can cause a malfunction.
Connect a resistor (RD) as shown in the following figure to bypass the reverse current for these types of loads. However, the amount of current to the load decreases by Irp.
Please be careful to use a resistor with sufficient rated power for R
D. If a resistor with insufficient rated power for the circuit is used, the resistor will burn out.
