This is a known issue reported with ID 322019.
To set the correct date for the DST, modify the
RTTarget.DSTRule token in the
ni-rt.ini file.
Instructions on obtaining and modifying the INI file can be found below:
- Use WebDAV or FTP to copy the ni-rt.ini file from the Real-Time controller to the development computer.
- Open the ni-rt.ini file in a text editor.
- At the top of the file, there is a section named [LVRT], which is where the token may be found or added.
- To change the DST setting either add or modify the RTTarget.DSTRule token to the INI file.
The format for the token is as follows.
For example, to manually set the Europe regulations, rules for the DST (01:00 UTC on the last Sunday of March) and STD (01:00 UTC on the last Sunday of October) would be defined as:
[LVRT]
RTTarget.DSTRule = 3.5.0.1.0,10.5.0.1.0
