Based on this link , it mentioned this VI obtains date and time info from computer clock. If I use my cRIO or other RT target, will this vi gets date/ time info from RTC or still getting from computer clock?
If I use the ptp synchronization function of my cRIO to synchronize the clock, will the Get Date/ Time in Seconds function reflected with the synchronization as well? or should I use timesync function to get the time?
