Note:
Using the TS API in code modules is not encouraged.
The reason is that the code module is then bound to TS and cannot be reused in any other context.
However, there is obviously an exception:
Termination Monitor for extended test time modules (>single digit seconds) and using TS synchronization tools like queues and notifications in parallel running VIs
