How to Implement HTML Map Tag in G Web Development Software
Updated Mar 25, 2024
  • G Web Development Software
The HTML map tag is used to define an image map. An image map is an image with clickable area, which can be hyperlinked to another URL destination.
This document describes how to implement map tag on a WebVI Front Panel in G Web Development Software by using some example files. This document assumes that you have basic knowledge on HTML code.
1. Launch G Web Development Software and navigate File >> New >> Project. This will create an a new project. Save the project in any desired location.
2. Download the zip folder in the attachment below and unzip it to get the content files.
3. Right click on WebApp.gcomp to import the content files. The files will be copied to the Web Application document folder.
4. Click Edit HTML Source to load the HTML code for WebVI front panel.
5. Replace the existing HTML code for the WebVI front panel with snippet code below. Then, click OK to load the modified HTML code and observe the changes done on the WebVI front panel.
<ni-front-panel control-resize-mode='fixed' layout='absolute' ni-control-id='2'>
                <h2> Image Maps</h2>
                <p>Click on the computer, the phone, or the cup of coffee to go to a new page and read more about the topic:</p>
                <img src="workplace.jpg" alt="Workplace" usemap="#workmap" width="400" height="379">
                <map name="workmap">
                    <area shape="rect" coords="34,44,270,350" alt="Computer" href="computer.htm">
                    <area shape="rect" coords="290,172,333,250" alt="Phone" href="phone.htm">
                    <area shape="circle" coords="337,300,44" alt="Cup of coffee" href="coffee.htm">
                </map>
            </ni-front-panel>
6. Click Run in browser to run the WebVI.
7. The WebVI will run automatically on a new internet browser tab. Hover the mouse over the image on the WebVI and click on area where the mouse cursor changes its shape.
