SCB-68A Pinout Diagram On Connector 1 With NI 62xx/63xx
Updated Mar 28, 2025
  • SCB-68A
  • What is the pinout of my SCB-68A terminal block when connected to connector 1? The pinout of my SCB-68A terminal block does not reflect to the pinout for connector 1 on my NI 62xx/63xx device.
  • When I receive my NI 62xx/63xx device, the label on SCB-68A terminal block cover only works on my connector 0. When I use the same pinout for connector 1, I am not getting expected measurement.
SCB-68A terminal block follows a different pinout on connector 1 of NI 62xx/63xx hardware than the shipped pinout cover. The actual pinout cover diagram for connector 0 and 1 can be obtained from this link. The pinout diagram can be cut and pasted on SCB-68A terminal block if required.
