Can we output captured data to file with Digital Pattern Editor?
Updated Mar 25, 2024
  • NI-Digital Pattern Driver
In this documentation file , it is said that the "capture waveform configuration" is used to view, modify, save, and load captured waveform files.
Can we output the captured data to file?  If so, how do we actually achieve that?
Yes, you can save captured waveform into files.
You can test it by use of Digital Pattern Editor without hardware (demo mode).
There is a sample project in the following folder:
(C:\Users\Public\Documents\National Instruments\NI-Digital\Examples\C\Capture Waveform)
enter image description here
