Previously, I was using the NI OPC Server 2010 version, and it was working fine. However, when I upgraded and installed the NI OPC Server 2012 version, the quality of the tags was labeled as “Bad” or “Bad (out of service)”.
When I close or terminate the servermain.exe process in Windows, the quality of the tags becomes “Good” and I can read the tags in LabVIEW. However, after a few minutes, servermain.exe starts running again and the issue persists. It seems like this issue persists if servermain.exe is running. Is there any explanation for this issue?
