I am using a NI SMU and PXIe-6571 in my test sequence. The NI SMU will occasionally throws error and then our test sequence will skip the close session step of the PXIe-6571. When we try to run the test sequence again, we encounter the error -1074102162 in the PXIe-6571 initialize step every time.
Each time when this error happens, windows will turn into blue screen for 10 seconds. Only ac power cycle can fix this issue. Why is this happening?
The driver used is Digital Pattern Driver 19.0.1.
