I have a CompactRIO (cRIO) controller daisy chained with CompactDAQ chassis (cDAQ). I have a NI-DAQmx task that contains a thermocouple module inside the cRIO and a strain module inside the cDAQ-chassis, so this is a multi-device task. When running the NI-DAQmx code (developed in LabVIEW) shown in the VI below, error -200284 shows up just after the
DAQmx Perform Bridge Offset Nulling Calibration.vi (this one was used in the example) or
DAQmx Perform Shunt Calibration Ex Strain.vi. The issue is only present when the
CJC Source input of the
DAQmx Create Channel (AI-Temperature-Thermocouple).vi is configured as
Built-In.
Error -200284 occurred at DAQmx Perform Bridge Offset Nulling Calibration.vi:1900001
Possible reason(s):
Measurements: Some or all of the samples requested have not yet been acquired. To wait for the samples to become available use a longer read timeout or read later in your program. To make the samples available sooner, increase the sample rate. If your task uses a start trigger, make sure that your start trigger is configured correctly. It is also possible that you configured the task for external timing, and no clock was supplied. If this is the case, supply an external clock.
I am using a cRIO-9047+NI-9213 and cDAQ-9189+NI-9236. Both the cRIO and the cDAQ are TSN-enabled. How can I fix this issue?
