This error occurs when the structure of the Jupyter Notebook output data is incorrect. Common causes for incorrect data are:
- Mismatched parameters in the Jupyter Notebook.
- Incorrect output data type.
- Incorrect output data structure.
- Errors occurring in the Jupyter Notebook.
To resolve this issue, follow the relevant sections below.
Cross-Checking the Notebook Parameters With the Inputs and Outputs
- In the Code Cell that defines your input parameters, open the Property Inspector.
- Cross-check the properties and syntax of your parameters with the inputs and outputs defined within the notebook.
- For example, the image below indicates that the notebook expects to receive a numeric input called num_elements, and output a single [External] DataFrame with an ID of randomdata. In this scenario it's important to check that:
- The num_elements input parameter is defined and used within the notebook.
- A [External] Dictionary with type, id and data Keys is defined, where id is set to randomdata and data is a Dictionary of a DataFrame.
Property Inspector Showing Cell Metadata:
Checking the Output Data Type
- Scroll through the Cell Metadata an identify the type associated with your output(s).
- Check that the type matches your output data structure. Valid values are data_frame or scalar.
- In the example below, the output data is expected to be a DataFrame.
- Check the notebook to ensure that the data is contained within a DataFrame, and that the DataFrame is inside a Dictionary that is glued to the notebook.
Cell MetaData Defining the Output Type:
Code Cell Defining the Dictionary that Includes the DataFrame and Sets the Type Accordingly:
Checking the Output Data Structure
- The output data structure should resemble the following:
- Initial output data is a Dictionary.
- The Dictionary is converted to a Pandas DataFrame.
- The DataFrame is included in a new Dictionary with Keys columns and values, where values is the DataFrame values as a list.
- The Dictionary from step 3 is included in a new Dictionary with Keys type, id and data, where data is the Dictionary from steps 3.
- The Dictionary from step 4 is glued to the notebook as a list
- The images below show how each of these steps is implemented.
Code Cell Defining the Initial Dictionary and Converting it to a DataFrame (Steps 1 and 2 above):
DataFrame is Included in a Dictionary, Which is Then Included in Another Dictionary (Steps 3 and 4 above):
Final Dictionary is Glued to the Notebook as a List (Step 5 above):
Check the Jupyter Notebook for Errors
- The output data may not be populated as expected if the notebook encounters an error in an earlier Code Cell. In Jupyter:
- Press the
button to restart the Kernel and run the entire notebook. - If an error has occurred, it will be detailed below the problematic Code Cell.
